sl1eseal
Hello everyone,
I need some advice on finding the type of fitting I need to connect my 1-1/4 P-trap tailpiece from my bathroom sink into a galvanized waste pipe in the wall. My home was built in 1960, but this was the first time I messed with this plumbing part. I had a crack in a pedestal sink and therefore tried to replace everything at once (i.e., sink, faucet, supply lines, P-trap) due to the unknown age of the parts. When pulling off the P trap tailpiece wall escutcheon, I saw the tailpiece was not screwed into a fitting. It was just stuck into a hole in the galvanized waste pipe in the wall with some kind of white gum substance (plumber's putty?). The 1-1/4 tailpiece (chrome) fit very snugly into the hole. (See the first image of the hole in the waste pipe). It looks like there is a circle of brass on the waste pipe hole rim....maybe built into the design? I checked the similar plumbing in a neighboring bathroom and saw that its tailpipe was attached to a similar waste pipe setup with a threaded brass fitting between the waste pipe and P trap tailpiece and a zinc nut on the tailpiece side. I really don't want to have to take apart this other setup to identify the part because of the age of the plumbing. I may be stuck fixing two faucets! Any idea what the missing fitting I need is? Thanks for your advice in advance.
