What is an Evaporation Control ? - Is your shower's flood test leaking or not?
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
johnfrwhipple submitted a new resource:
What is an Evaporation Control ? - Is your shower's flood test leaking or not? - The only way to measure evaporation in your shower's flood test is with an Evaporation Control.
A simple site build rig that measures the rate of evaporation. Some pointers to help you set this right.
The coin shows the key step to the evaporation control. It is measuring the water level in this shower flood test.
Anything can help set the control. A baking dish, an old tool box - something water tight. I like to tip the stack of coins the same way in the evaporation control...​
Read more about this resource...
The tipped coin technique.
Using a tip coin was my way of breaking the surface tension water has. The coin is tipped so the water rests across the center of it. A simple set to measure the water level very precisely.
It is important when working with Kerdi, Kerdi DS, Hydro Ban Sheet membrane, NobleSeal CIS or TS to plan on capillary breaks.
You can see the use of Ardex 8+9 here in this photo as a capillary break. Had I followed Schluter's install methods for this low curb shower we would have had water wicking up and over the curb giving use a false read.
