Wet Venting, Plumber Made Mistake, Opinions
Cass
Yes...a low spot in the waste line that can cause problems over time by allowing a build up that will cause a stoppage.
traps
IF a trap is going to siphon, it will happen regardless of how "DEEP" the seal is, unless it is 27' deep. Two things can siphon a trap. A pipe full of water as it empties, (and the trap has to be higher than the pipe), and/or high velocity water past an opening. Neither of which should happen when a 2" pipe is emptying into a 3" one. You have a poor installation, but one which will work without problems.
Master Plumber Mark
www.weilhammerplumbing.com
HJ...the deeper the trap the more it takes to completely siphon
HJ...I was just trying to ease the fellows mind...:D
although I disagree with you on this,, I feel that
a deeper trap takes a whole lot more suction to completely siphon it all out enough to break the trap seal...
I dont particualry care to do this,
but being the hack that I am,:D:D
it is something I have had to do on occasion in dire situations....
we both agree that it will work as it lays,,
Cookie
Home
Thank you Cass, I had a feeling that was what it meant and I wanted to be sure. In the 5 years, I have been here, I have learned alot about plumbing. I even sell plumbing supplies on the side. I even corrected my own foundation drainage problems and my downspout drains to move away rainwater. I am good... I am fully in the trades. And, absolutely, no hack. :) I do good work.
I even do for my neighbor's... I learned alot here from most plumbers.
