Wet vent into utility/laundry sink
Joshua5438
South Carolina
I know I cannot run the drain from a utility/laundry sink into the drain/vent for my bathroom sink but can I do the reverse? Run my bathroom sink drain into the drain/vent of my utility/laundry sink? Reason for asking... My shop will be on a small septic tank. My bathroom sink does not have a dedicated drain so I plan to wet vent it. It's between a toilet and a utility sink that will be outside of the bathroom. If it wet vents into the toilet it will obviously go to the septic. If I can wet vent it to the utility sink then I can run it out as gray water.
yea I suppose but you've got a vent for your water closet right? septic is for toilet only? will it have sufficient water?
Joshua5438
South Carolina
I do have a vent for the toilet. I plan to only run the toilet to the septic. I will have a shower, toilet, sink and then the utility sink. Do you see an issue with only the toilet being on the septic?
John Gayewski
Iowa
Human waste (toilet, dishwasher) goes to septic. Everything else is greywater.
Check with your locality what the expectations are for greywater. You should be able to dump it on the ground. But some places have rules about it.
No I don't know a problem with it , just a question as to whether septic function would be any different with a reduced amount of water. I've never plumbed grey , and it used to not even be legal .
the venting sounds good
