Could you say more on that? Are you saying that if you set your pressure to 30/50, the micronizer might stop sucking air in once the pressure had risen to maybe 37 psi? In that case, it seems to me that the micronizer would have the ability to suck air into a certain max pressure, and that you would adjust your water pressure to work around that. Is that it? So you might find that the pressure that the micronizer stops sucking air, and set your cut-on pressure to 7 psi below that?
In theory, it is more the GPM than actual pressure but in actuality, the pressure (differential across the venturi) does play a role. Since pumps run on a curve, at the higher pressure, the GPM is less. At the higher pressure with less flow, you get less differential across the venturi so no vacuum can form to suck in air.
When I replaced my 10 GPM Goulds pump with a 10 GPM Grundfos, the new pump could produce higher pressure and GPM on the upstream side of the venturi in the micronizer and so it could suck air at higher pressure. If I were to size my pump for a deeper well, it would produce even more pressure and subsequently suck more air.
I use a Waterite micronizer that has an adjustable bypass which I adjust to draw air for the first 3rd of the cycle which is standard practice. If I reduce the bypass to get it to draw more air, it also reduces the GPM which goes contrary to the theory. I grew tired of the "experts" trying to tell me that it is GPM that determines whether or not it sucks air. It is the GPM going through the venturi, not GPM going through the bypass but the experts seem to be deaf to that distinction. I could run two micronizers in parallel to get more GPM and more air, assuming my pump is up to the task.
I don't do much irrigation but when I do, my zones are sized to draw just enough water to prevent the pump from reaching cutout pressure and so for that duration, the micronizer does not suck air. If I did a lot more irrigating, I would have to change how I do it, probably by adding an air compressor to inject air for 100% of the pump cycle.
