OK update, I moved the pump from the room in the barn to the well head. It's now located about 3 feet from the head. Everything is hooked up. I had electrical reconnected, because evidently the pump was located here at one time. The new issue is this, the pump is connected to the electrical but when I turn it on all it does is humm, it does not turn on. I took it off and took it to the company here that services these pumps to check it out. They told me everything is running fine with it. So I took the pump, reconnected it, hooked up the electrical and it did the same thing, hummm. So now I am at a loss. Any suggestions?
