Bgard
The pipe from the well to the pimp is 1 1/4" the 1" is the exit for the water out of the pump. I am not sure what you mean by "deep well". All I know is the pump was getting to about 40 psi but now reaches only just above 20 psi.
A two pipe system doesn't have any vacuum in the the two pipes. The only place there would be vacuum is the tailpipe of the jet assembly down in the well.
If you are open to making changes, consider switching to use a submersible pump if your pump casing is 4 inches or more ID. A 1/2 HP pump would normally give you about the water of a 1 HP jet pump.how far should the pump be from the well head? Right now it's about a 100+ ft.
Had he been more responsive to questions, that could have become clear earlier.Looks like a shallow well pump.
The odds are pretty good. As I said the electrician found that two weres were crossed. Pump no works but does not reach 560 psi.Had he been more responsive to questions, that could have become clear earlier.
I also what are the odds that he actually measured 11o volts?
I did that but will do it again to make sure.Looks like a shallow well pump.
Jet nozzle probably plugged. Open 1/4" plug on back and insert wire to rod out.
