I recently purchased a home with a well water system. All was inspected in November and only needed a new tank. My pressure switch is set from 40psi to 60psi. The pressure switch is engaging to the energized position when it gets to 40psi. However, the pump will only run in 5lb increments with a minute between until 60psi when the switch cuts off. When my pressure drops to around 35psi, it just dives down to zero and I get air out of the lines once it gets back up to pressure. I am waiting on a well guy to check it out, bit does this sound like a bad pump?
Thanks for your input. Joe
