Sprinkler
Hi, I'm interested in buying a specific water pump for a 60 metre well - I want to install the pump at 25 metres from the surface- the pump in question has a max water lift of 54 m and a submergible limit of only 7 metres. I want to install the pump at 25 metres from the surface, so a total lift of 54 m would be more than sufficient.
My question is why is the submergible limit only 7 metres if the total lift is 54m? Could it be because there is a plastic floating switch attached, which would implode at levels below 7m ? Thanks.
