Sounds like a case for installing an old, used water gulping toilet.
Forget all this 5LPF stuff.
Get yourself a 5GPF toilet and don't look back
The point was, the water spreads out and slows down once it is no longer constrained into the same size as the nozzle.If you cut the flow from your hose back by 70% it won't move the dirt in your driveway as far.
My favorite pre-3.5 gpf mandate are the American Standard Cadet and the Gerber Mount Vernon. The Cadet was "prettier," but the Mount Vernon was less prone to clogging. I have one of each but can't, in good conscience, bring myself to install and use them.After seeing that video with the clear DWV pipes, I am again happy for my 1950's Eljer 5-6GPF toilet, and continue to promote it. A lot of folks I meet are unhappy with their "low flushes", and your suggestion is exactly what I have been telling them.
I also noticed some folks with older toilets are not totally aware of today's "low flushes". I tell them about it, and by the time I am done, they will keep calling me back to fix their old ones indefinitely.
Also if needed to try, would the pressure assist tank fit on the regular Cadet bowl? The bowls seem the same but AS would not authorize on the phone.. Thanks
