Dave3333
First time posting. I read through other booster pump posts but dont think they directly answered my question.
I'm having an issue with water pressure/volume at my house. House was built in 1938. Turning on one faucet no real problem. But turn more than one on or use an appliance like washer machine or dishwasher and taking a shower is not possible. The pressure/ flow drops significantly to where you basically can't take a shower.
Pressure coming into the house measured at 45 psi on outside spigot. Did a flow test in the basement at the closest faucet to water meter and I get 2.5 gpm. From what I'm told the pressure isn't actually to bad its really the volume/flow that is the problem. The water line coming into the house is old galvanized pipe. I'm assuming this has clogged up over the years, and that's why the volume is so low. Replacing this is not an option right now considering I'm being told it could cost anywhere for $5,000- $10,000. I need a cheaper solution.
Can I just add a pressure booster pump and fix my problems? Found THIS ONE and was told by someone else it worked very well to increase pressure in their house.
Or because the volume is so low just boosting the pressure won't work and I actually need to add a storage tank along with a booster pump? Something like THIS
Or is there another soultion?
Any advice/help much appreciated. I can't listen to the wife complain about the shower anymore!
