Scott Kimball
I have a new house that is on a hill 100 feet above the meter with a run of 750 feet. The water company will give me a 1" meter and I plan on installing a booster pump just after the meter. I'll have a pressure tank in the garage like you'd have with a well. The house is 3500 s.f. with 3 bathrooms, and all the normal fixtures plus some lawn irrigation. What size pipe should I use to eliminate friction all the way up to the house? I was thinking of using 1 1/2" poly pipe to eliminate any joints.
