fred becker
I read about common problems with supply line leaks on water heaters... and the recommendation to NOT use teflon tape (the washer provides the seal).
For my installation - i think it's fairly typical around here in California - the cold water supply to the water heater location is a threaded pipe. To this is threaded a shut off valve, a short stub threaded on each end and then the flexible supply line. The flexible supply line with two threaded female ends typically has a washer in each end.
My question: Should there be a washer at each of the threaded connections? i.e. when I install a new shutoff valve, should I be putting a washer before and after the valve?
Yes, I've done two water heaters in the last 6 months, and have a tiny leak at each of the stub nipples. Not sure i can get them any tighter without breaking something.... wondering if I just need to add a washer?
