replacement rubber washer for supply line
California
I was going to replace the everbilt washing machine supply line rubber washer.
I bought an everbilt supply line rubber washer replacement.
The inner diameter of the replacement washer is larger than the original washer I just pulled off.
I see that the package says water heater supply line rubber washer. Which I guess is different from the Water supply line for a washing machine?
Should I not use these replacement washers seeing that the ID is different? The OD is the same. I think the ID is like .62 of these new washers.
Can I use them still and if not, how to I search for the correct washers? Thought I got the right thing, ugh
