Water heater - one notch cold to hot
Themp
Active Member
Raleigh, North Carolina
Tell me if I'm wrong Sylvan, but I think it's safe to shut down the water heater and keep it at room temp, assuming the room is normally below about 75 degrees.
Found this on a Canadian CDC website:
* 70 to 80 °C (158 to 176 °F): Disinfection range
* At 66 °C (151 °F): Legionellae die within 2 minutes
* At 60 °C (140 °F): Legionellae die within 32 minutes
* At 55 °C (131 °F): Legionellae die within 5 to 6 hours
* Above 50 °C (122 °F): They can survive but do not multiply
* 35 to 46 °C (95 to 115 °F): Ideal growth range
* 20 to 50 °C (68 to 122 °F): Legionellae growth range
* Below 20 °C (68 °F): Legionellae can survive but are dormant
So, at 140 degrees F to the shower heads and faucets, it takes 32 minutes to kill it. Not going to happen in my household...
Where is the legionellae going to come from? You can sanitize your system after doing work. It does not come back from spontaneous generation.
DIYorBust
Active Member
Long Island, New York
I don't think it's as big an issue at the taps or showerheads, since they are not warm very long. But the water heater could house bacteria for a long time at the set point, and doesn't completely flush out with each use.
Sylvan
Still learning
New York
When going on vacation depending how long if it is wiser to just shut it and relight it when you return
Unlike a boiler a water heater has one safety device the T&P a Boiler has high limit and LWCO plus either a safety or a relief valve plus operating controls
Sylvan
Still learning
New York
A former Shoreline firefighter who claims he was badly burned by scalding hot water from a shower in the King County Jail last year has sued the county for negligence.
https://www.seattletimes.com/seattl...as-badly-injured-by-scalding-hot-jail-shower/
This is very common where someone says "Shower spoked to extreme temperatures"
As you know I work for over 37 law firms and over the past 30+ years the majority are scalding cases
By saying the water was too hot the "victim" has nothing to lose by contacting a personal injury lawyer as they get a percentage of the award given.
In the majority, the cases are settled out of court as it is time-consuming and expensive to defend against these actions
In one case the "victim" said the water scalded him when I was hired by a law firm I said the water temperature never spiked about 110 DEG
I was asked and paid to "find what possibly caused water to spike " so I gave my expert opinion on what could have caused the spike in temperature.
The city lawyers tried to get me disqualified but I proved I was not only an LMP I was a stationary engineer and the NYCHA offered me a job to be the chief of mechanical installations which I turned down years before
https://pospislaw.com/wp-content/uploads/2013/08/Clinindin-v.-NYCHA.pdf
