Question about Electric Hot Water Heater problem
joarimathea
south carolina
I apologize for the long post, but a lot has gone on with it.
The real question I am asking is why does the temp of the brass fitting on the hot water heater cold inlet go up when the hot water is running? That makes no sense to me.
We have not had what I would call Not great hot water since we moved into this house about 2 years ago. It would be warm and last about 10 minutes in the shower. My wife likes hot 20-minute showers. I called a plumbing company recommended on our HOA community forum. I could not be home as I work all day through the week. The plumber told my wife that the water heater was only 3 years old. It is AO smith. He said it might be the dip tube, but as it sits on a pedestal about 4 feet off the garage floor, that he would have to take it down to check the dip tube and that would cost $1400 due to labor of removing and reinstalling. The cost of replacing the hot water heater would be $2000. I became concerned when my wife stated that the plumber also had concerns that the water heater is too small. It is 30 gallons, but it is just my wife and me. In our previous house, we had 30 gallons and did just fine with it. It worked better than we have now. A larger hot water heater would need a new platform and that would be very expensive. We were not given a quote for a larger heater.
I just don’t want to pay that much money, and it does not work any better than what it does now. Then the plumbing company just says that the water heater is not big enough. I am middle class and that is a lot of money for me. I don’t mind paying good money for good work, I just am not confident that the problem will be fixed when they are already hedging. We just paid for the service call for now, as we can still shower.
Here is what I know. When turning the shower on, after about 2 minutes it gets hot. It’s too hot for me and I turn it colder. After another 2 minutes, I turn it back up to full hot. It gradually gets cooler from there and is only slightly warm after about 12 minutes. This is with both water heater thermostats turned up to max.
I am also concerned about some of the strangeness how the hot water heater operates. My fear is that when it was installed 3 years ago the hot and cold lines were switched and it may be acting like a dip tube problem. I used my wife’s cooking thermometer to get some measurements.
Water out of the hot water heater drain valve is 128.5 degrees
Max water temp out of bathroom faucet is 126.3 degrees.
With hot water not running temp at brass fitting at cold inlet on hot water heater 73.0 degrees
With hot water not running temp at brass fitting at hot outlet on hot water heater 83.3 degrees.
With hot water running temp at brass fitting at cold inlet on hot water heater 99.9 degrees
With hot water running temp at brass fitting at hot outlet on hot water heater 71.8 degrees.
I have a bunch of pics but this one is on the cold inlet when the hot water is running. My wife was in the shower. I will post pics below.
