Looking for some expert opinions on how to run water service into my slab before they pour.
I'm in south louisiana and our code is 2015 IPC. Please excuse this rough sketch below. Just jotting down ideas. I'm not planning to have "home runs" to the water heater.
Blue circle - Shut off with 1" pex going under slab into wall inside the house. Switching to 3/4" pex and running through wall to refrigerator ice maker.
Red circle - I want to eventually run a water spigot to the side of my shed about 15' away. Can I branch off of this line in the house and run under slab to the outside of shed?
Yellow circle - Tankless gas water heater on exterior. Cold water will run through the house to the hot water heater and then hot water lines will go out from there.
Will this work or how should I lay this out? Thanks for any advice or tips.
