Hello,
We bought a home two years ago and went out and bought various faucets. We bought a shower tub set, the Price Pfister 808-DC. Well, here we are two years later and I'm just getting around to trying to install it..
Our current water control is an unknown brand as I can't see any name. But it has a knob that you angle upward and it turns on the water. The higher you lift it the more pressure. Turning it right or left makes it colder or hotter. The new 808-DC unit is just a handle that you rotate to one side to turn off and in the other direction to turn on, and I'm assuming the further you go the hotter it gets.
The 808-DC comes with a valve body, but I'm not that plumbing inclined to do all the pipe cutting/sweating to swap the valves. Does anyone know if I can put the 808-DC's handle on the existing valve? I'm assuming the cartridge in the current unit should be removable but I don't know how compatible they are. It seems that other than the lever action of the current knob, the left/right is the same.
Otherwise I might just hire a plumber, but that would probably be next year when we have some extra cash.. Right now the tub faucet is leaking ever so slowly, so the project got bumped up to now vs later.. If a plumber is required then I'll probably replace the cartridge now to at least stop the leaking.
Thanks,
Dave
Thanks,
Dave
