Updating an old Moen shower valve with pictures. TL473 or TL470
Do you have an old Moen valve from the 70's or 80's? I love updating those old valves in the Seattle area. Replacing the cartridge makes them a new faucet, smooth and quiet.
Turn this into this!
Moen TL473 trim fits the old Moen roughs. The T473 has the crystal knob, the TL473 is the lever.
Or for just the handle and plate, T470 crystal knob and TL470 with lever.
Theses came with the 1200 cartridge, and will accept both the 1200 and the 1225.
Replace the cartridge while you are at it.
New cartridge in, face plate on............
The backing washer before the knob.
Tightens with an Allen wrench.
emilio
Tacoma
On the old handle how do I remove it? Does the front plate come off or something? I got one like in the first photo. :(
-Emilio
With a new 1225 cartridge.
Home built in 1977.
I installed hundreds of these valves in the 70's.
And removing the clip and pulling the cartridge.
tapau
Pembroke Pines, FL
Hi, I would like to convert from the old Chateau (your first picture is exactly what I have) to the TL473. I have the 1200 cartridge and just replaced it. Does the TL473 only work with the 1225 cartridge?
Also, I do notice that there are 2 pictures that have some black plastic pieces (pictures 7 & 8). Do I have to purchase those pieces in order to use the TL473? Is so, can you list those part numbers please?
Final question :) ... can I also update the handle on the matching Chateau sink faucet or is it not worth it and I should just get a new Moen matching sink faucet?
Thank you.
your valve takes a 1200 or 1225 cartridge your choice brass or plastic. I think that modern style trim was desighned for a newer valve though its possible and looks like Terry shows using that trim so I guess so
bpalmer999
We have a similar moen but it has the non-diverter spout and the little diverter button left and below the mysterious crystal knob.
Is there a plan for this kind of lever update for what we have? We'd like to update the spout too, but ine thing at a time.
this thread is on shower cartridges but yea tub spouts are easily replaceable
Dont know what your question is ? are you wanting to change a valve? cartridge? or spout?
Quilbilly
Washington state
Home built in 1977.
I am having an issue with my replacement. I ended up getting the tl471 trim kit which is great, but I it didn’t have the stop tube and I don’t have one that I can find that fits this 1200 cartridge. Moen tells me it’s the 10089 stop tube but that is too big for the cartridge and trim kit. Any help would be great.
itsmekc
What is the difference between the 473 and the 473EP? I live in a very rural area and will need everything when we get into this project-can't just run to the hardware store. I found out I need the 1225 cartridge, but I want to change the trim.
Bruski208
Harrison, Idaho
Hi Terry,
I used the information here to order some replacement trim parts after I had replaced the cartridge. I ran into an issue removing the old cartridge. It cam apart, that is the center portion came out leaving the outer portion in the brass. I found a YouTube that showed me how to remove it by using a 1/2" tap and then threading a bolt into it and using that as a puller. I got it out. I cleaned it up. BUT -the new cartridge would only go in to a point (about 1/2" to 3/4" from full insertion.) So, I tapped it in with a hammer (gently.) Then, concerned of future problems, I pulled it back out -but the brand new cartridge did the same thing -it came apart! So, I left the outer portion in the tube and reinserted the guts.
I am only telling you this as I would like your opinion on what would cause this (corrosion?)
I have already decided that if I need to do any other repairs on this plumbing that a professional will be hired to replace it all.
FYI, this is a 40+ year old home.
