Hi All,
I need some advice and guidance from all you experts!
As you can see the plumbing under my sink, my question is in regards to the dishwasher drain. Its hard to tell, but the DW drain on the branch piece is slightly above the discharge level after the P trap. My question is, i know normal configuration places the DW drain on the tailpiece of the sink strainer, but does the configuration pose any issues?
I have not had any issues with the DW draining, and the drain tube has a high loop to prevent backflow, but would it be better to redo the plumbing underneath to raise the DW drain more?
Also, if it would be better to change things around, would it make sense (or would there be nay issues) would placing the DW branch horizontally where the red arrow/circle is?
Thanks all for the support in advance!
