Two inch well question
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
LLigetfa, i like how you think. seems i've seen such a diagram, at the flint & walling website, i think.
what's the trade-off with this configuration...why wouldn't we normally assemble it this way?
Sorry, I missed this question. A jet pump pushes better than it pulls, so putting the jet/venturi as low as possible produces the best results.
As for Porky's last comment, I'm confused. I have not seen any bad advice and in fact the only advice is justwater which I agreed with. Whether or not you would pull sediment or contaminated water through the hole in the casing if the lower leather was not used, is anyone's guess since we don't have details on the well, formation, etc..
liam o k
indiana
i've determined there is hole in the 2" casing at about 14.5 ft. my intention tomorrow is to reinsert the well pipe with the foot valve on the bottom, the 1" pipe up to about 13.5 ft.below the well head, the ejector packer, then the balance of the pipe to the well head. if anyone sees fault with this plan, please inform me. thanks
(don't know why, but i didn't see the last six postings 'til just now)
liam o k
indiana
i'm sorry, justwater, but i'm not totally clear on you description. i understand the intent to create a seal above and below the hole in the 2" while letting the 1" pass through, but you say "however much 1" pvc to get a hair past where the jet was set originally"--- it was originally set near the bottom of the well; --- "on the bottom of the pvc... a 3rd leather cup to seal off the bottom of the pvc." in my mind's eye, that looks like a 1" diameter deep well. after the third leather cup is affixed, then what? an open pipe? a foot valve? am i right to assume the cups are actually to be seated just above and just below the hole, while the remainder of the pipe continues to the bottom of the well? your plan is the direction i'd like to go in the morning, so please reply.
Justwater
Well Drilling/Service
FL/GA
it's just an open pipe off the jet/check with seal at bottom to block hole. u know u can put the bottom seal 30' total so don't go less. The more old steel pipe u can comfortably block off the better off u are.
or u can come strait off the jet assembly with the tailpipe (no inline check valve) and set a footvalve at the 30' with a seal just above the foot.
Good luck.
liam o k
indiana
many thanks!! one more question: i recall there's a dispute--- to soak or not to soak leathers. i worry about pushing a seated leather over the hole and down a likely corroded pipe. any thoughts?
Justwater
FL/GA
i do not soak leathers. I just flare them out with a flathead screwdriver and install. they can soak/swell when set in place.
liam o k
indiana
it's holding water!!! today, the pump...
i'm a historic hone renovator and antique tool woodworker who, unfortunately, lives in a modern world. so i'm occasionally forced to seek help with computer software and hardware. (i'm also poor, so nothing's ever new.) i comb through pages of insulting, back-biting and positively uncivilized behavior at the computer help sites, hoping to find buried, rare pieces of sincere advice. what a breath of fresh air to come to a site like this, where the only input is knowledgeable effort to actually help a poor ignoramus like me. thanks to everyone. i'll let you know how it comes out.
