Tub Drain Type & Brand advice sought
GA_
Georgia
I'm going to replace three current twist type tub drains with toe tapper type drains.
I'd welcome some advice.
1. The flanges ( or shoe - the metal part that seals or screws to the PVC drain and stays in the bottom of the tub) have become pitted and corroded. This started after only a few years old, I presume due to cheap parts. This part is better replaced by a plumber since if not done correctly it will leak. Plumber told me to get all the parts before he shows up. I would like to buy replacements that will stay looking good longer without pitting or corroding.
What brand or materials should I look for? How do I determine if I need a 1 3/8" or 1 1/2" replacement?
2. The plug stopper part will be a toe tap type because they look good, seem easier to operate and easy to remove for cleaning, and easy to replace if needed.
What brand is better than others?
They sell kits with both the above parts plus an overflow drain cover.
The Delta brand kits are $80. I'm presume they are good quality.
The HD/Lowes kits are $10. I presume they won't last.
What is a good brand/model number/material that is durable, finish will last but might not be quite as costly as the Delta brand?
Thanks.
Sylvan
Still learning
New York
FIND another plumber
The "plumber" who stated
"Plumber told me to get all the parts before he shows up."
In my opinion not worth even considering to hire
When my employees are asked about parts we ask a picture be taken and sent to us so we will supply parts
Because of liability we very seldom install "parts supplied by others"
GA_
Georgia
Thanks. Unfortunately, that is easier said than done in this environment. In my part of the country plumbers are booked months out. This guy comes highly recommended. He is a two person operation, and indicated ordering specialty parts such as toe touch drains takes too much time, so he prefers I just buy.
My main concern is that the piece that stays attached to the tub and connects to the PVC drain be long lasting. Any recommendations?
Sylvan
Still learning
New York
Ask the plumber if you take a picture would that help . I never used a PVC drain only non ferrous metal
GA_
Georgia
He just wants me to get the drain type and finish I want and have it ready for him. Seems reasonable enough.
I don't think these parts are PVC. They tie into (screw into?) the pvc drain pipe under the tub. I have never seen one under a tub that is not PVC except in an old house where they are cast iron.
Presumably Delta is a good brand, although pricey. Does the finish last? I'm fine going forward with this if they last
The Brasstech brand is more expensive than the Delta. May be worth it if the Delta finish does not last.
I know some of the cheap stuff is plastic with a coating to look like metal. That seems like a poor idea, but maybe I'm wrong.
Is Jones Stephans a good brand? They have what are called "Toe Touch conversion kits" that look like they have all the parts I need.
Tuttles Revenge
I would recomend that you buy a quality product from Kohler. It will likely thread into the base shoe that you have. The overflow may be another matter, so a photo of that may help in selecting a fit for that.
K-7142
Kohler Drain
In new construction we're mainly installing PVC or ABS tub drains. Inspectors want the tub drains without the connections that can loosen in concealed spaces. Sylvan works in NYC, lot's of high rise and it appears much different than what most of us are doing residentially.
We do a lot of solvent weld drains, stuff that is glued up. No slip joint nuts and washers.
I can't tell you quality wise which of the components are going to last longer for tub drains. They all seem pretty equal to me.
I install Watco most of the time.
I just looks at the Delta site. Wow! They charge a lot for a few fittings. I suppose if you're matching finish to the faucets and other hardware it makes sense though.
https://www.woodfordmfg.com/WATCO/Index.html
https://ipscorp.com/plumbing/brands/aba/waste-overflow/
GA_
Georgia
Thank you. I looked up Watco.
All of this work is being done from the tub - the plumbing under the tub and behind the wall is not easily accessible without cutting out gyp board which I prefer not to get into.
So I only want to replace the parts that are replaced from the tub - the parts with the metal finish. Can I get this Watco kit and they just use the parts installed from the tub and not use the PVC piping parts?
https://www.supplyhouse.com/Watco-9...lzewP1zeLOsum_1pEYovoU8daYc1z60oaAqlhEALw_wcB
Metal tub drains tend to have a fine thread and the plastic drains tend to have the coarse threads.
I would guess that it will work.
Sylvan
Still learning
New York
Hello Terry.
We are completing several one famly homes in Riverdale section of the Bronx
All of these houses were piped with type L tubing above ground K copper below and the vents and waste lines are all cast iron although plastic is allowed we only use it for chemical waste and Chlorine for pool applications
