Trying to install an utility sink
Derek Kai Leung Chung
FIXINGSTILL
California
I am trying to install an utility sink in a room next to my laundry room that already has a sink. The utility sink will be back to back to the laundry room sink. I am trying to tap into the existing water lines and drain pipe.
Change out both water shutoff valves to dual handle version, and run the new sink supply lines to them, thru the wall with holes?
How to add a tee to the drain pipe? Some sort of ABS saddle clamp?
They don't make a saddle fitting for that.
Normally a double fitting if you're back to back
This works if you have 2" to work with, but you might only have 1.5" there.
I sometimes do something like this with 1.5"
If you opening the wall up, you might as well cut in some new supply lines for the faucet in the next room too.
I am not a fan of double stops.
FIXINGSTILL
California
Opening up the wall would be my last choice. I prefer to open up a 14x14 hole so that I can then install an access panel (and drill holes on it for the piping).
I got 1-1/2" piping and I bought a "rubber" tee. Installation should be easy but my concern is if the tee branch would be too high (or low) to plumb to the new drain. I am trying to see if they make a double sided tee (like a cross).
Stacking two tee's on sinks like that will siphon the opposing p-trap. There is a reason we plumb the way we do. We don't do it to make our job harder, we do it to prevent sewer gas from entering the home. Just a thought.
Rubber fittings like that have never been code approved. They tend to deform over time. We can get them passed off on our inspections.
Terry made good suggestions. Look at his pictures, Wouldnt recomend the rubber plumbing junk.
FIXINGSTILL
California
I am a DIYer but can't do drywall nor sweat copper pipe. Also need this done ASAP to move on so I decided against what is suggested here. Afterall, I do not have to ruin my reputation or provide a warranty service for free if I have to redo it.
Now just waiting for couple 36" supply lines to come from Amazon...
No matter what. Thanks for the comments and the informative site.
I presume you will replace the washcloth with a cleanout.
This is a "spigot" cleanout that glues into a socket, as a pipe could. There are other types.
There are flush covers if you don't have the depth for one as shown.
Got it. So you will probably be gluing in a spigot trap adapter, cutting clearance holes in the access panel, and getting a suitable escutcheon-- possibly a box escutcheon or split escutcheon.
FIXINGSTILL
California
My son 3D printed some "grommets" for the drywall holes.
I know it is not professional. I do what I could with parts from HD or Lowes. This is for a saltwater reef fish room. I know when I move or sell my house, I need to remove this so this is good enough for now.
Thanks.
