Trying out CoolCalc - questions.
Boe
Hello,
I was testing out coolcalc and I got a solution for a 5 ton AC unit. I'd like to run that same scenario - same house, same insulation etc but test with a 2 ton and 3 ton unit with slightly different specs.
I' prefer not to have to enter all the info again.
Also I'm not familiar with latent cooling efficiency - can you tell me where to get that - it isn't in any of the ERV specs for two different units I looked at.
Erv's are under specifications manual not the install manual. Heres a Panasonic that has the info. Think a blower door test would have to be needed for tightness of building envelope.
  • Like
Reactions: Boe
Thanks - I'm not trying to be obtuse but am succeeding anyways. I clicked on the brochure, submittal sheet, install instructions, service manual and searched for the word latent - none of them had that.
Anyone know of another term than latent cooling I should look for that means the same?
Ventilation systems that transfer both sensible and latent heat the process called total enthalpy. Only have worked on commercial systems that relied on co2 sensors but now there looking at muiltiable iaq sensors.
If the info you have gives the sensible cooling, i.e. 48,000 btus, the remaining btus is latent (12,000). 12+48=60k btus or 5ton. 80% sensible 20% latent. The higher the latent capacity the better it is at removing moisture.
