Toto Drake Question
Lykele
I just installed a Toto Drake toilet and everything is fine. Like many others I am very pleased. I do have one question.
Occasionally, some people will make reference to a two step flush. In other words, pressing the handle quickly uses less water than holding it down a bit longer. Is this true?
The reason I ask is because the only documentation I have is the installation instructions and I can find no reference to this feature. Although, maybe it is a feature of all new toilets and I'm 20 years behind the times! Plus it uses so much less water than my old toilet that I can't really detect the difference.
So ... are there two flush options?
Thanks. Jim
Toto Drake Installation instructions
This is true of nearly all toilets manufacturered. It is designed to be flushed by pressing the handle down all the way, not flicking it. You can be pretty much assured it will flush anything in there away with that procedure as designed. Anything else may produce erratic results. But, like many things, with practice, you could probably get it to do what you want. In other words, no, it is not designed to be a two-stage flush. They do make them, the Aquia is one, but it uses an entirely different flush valve with two different buttons (one brand has you pull up for one and down for two).
bg
I haven't tried that 2 step deal, but I am so happy with
the Drake I installed close to a year ago, I wouldn't
hesitate to get another. It handles end business with
ease. Glad I came here to Terry's place to find out
about these things. Saved me a huge pain in the
butt..;)
