Toto Drake elbow neck 2in? What size wax ring?
Taocost
California
Hey guys, since planning on replacing 3 old toilets in an old house, I've gotten lots of good info here, so thanks to you all.
Ended up purchasing a Toto Drake, and AS Cadet 3, third one yet to be determined.
Q: just looking at the Drak elbow neck, its about 2in, previously thought it'd be 3in so purchased a 3-4in wax ring.
What size wax ring is correct?
Isn't it normally 3in elbow neck = 3in wax ring? so 2in wax ring for the drak?
GReynolds929
Active Member
WA
Most toilet outlets are around 2". The ring pictured will work fine. The 3"-4" measurement is the drain pipe size.
Taocost
California
That's good to know. Just picked up the Cadet 3 today, and its outlet is just over 2in as well.
The ring is sealing at the bottom of the toilet around what you pictured, rather than the OD of the protrusion that you pictured.
