Hi. I've got an OEM green-topped Toto 528 in my toilet. It's recently started to run all all the time as though the water line were set too high. I popped the green piece off to watch, and the float seems to engage, but maybe it's not fully closing the valve? If I press down slightly between the hinges, it seems to slow a bit - I think because I'm putting more direct pressure on the valve. Maybe there's a worn out gasket?
He's a couple photos so you can see what I'm working with. (I've currently got the shut-off valve closed to stop wasting water).
Do i just need a complete replacement valve, or is there some adjustment I can make? (Is there a user serviceable gasket?) Any input would be appreciated.
