Moved into a house where I noticed some mold and slight water damage in my basement shower. When I took out the rubber floor under the floor tile it was a bit damp. I don't know where the leak was coming from. Should I redo this drain as well (pic attached)?
You can see the bolts are rusted around the drain housing so I assume that it wasn't leaking at the pipe, but not sure
The pic is a drain with a p trap with a pvc pipe to the cast iron pipe which was (from what I can tell) a huge cut out then meshed and concrete poured on it.
Should I take this out or is it fine? I was thinking maybe I should take out the pvc p trap and redo it. What are your thoughts?
I want to make a mortar pan after.
