Toilet & Shower Vent Question
Josh Weight
Utah
Hello,
I am working on a bathroom remodel and have a toilet and shower right next to eachother. I am wondering if my plan shown below will provide adequate venting for both the shower and toilet? Just getting a little confused as to where the vent should be located. Thanks in advance.
James Henry
Billings, Montana.
You can do that but the shower drain must be at the same elevation as the toilet drain so the wet vent ties in horizontally. No vertical offsets on a wet vent allowed. " The horizontal pipe acting as the wet vent may not have vertical offsets".
Josh Weight
Utah
Well dang that's a bummer. Any suggestions on a different configuration? The shower trap comes out at a higher elevation than the closet bend and I don't want to drop the shower trap any more or else it won't be within the floor cavity.
Josh Weight
Utah
I got it all dry fitted together and I was able to get that shower drain to come in horizontal. Any way you could check out my pictures below and verify that I did it correctly? I greatly appreciate your time and expertise.
On a side note, I am a structural engineer and if you ever need any engineering help I would love to return the favor :)
That should work. Here I would need the combo looking up for the vent, but some places are okay with the santee. They used to be okay with that here too when I started off plumbing.
Josh Weight
Utah
Thanks very much!
Mike Rock
Long Island, NY
On a side note, are you allowed to roll the wye up at bit and have the wet vent come in to the toilet drain a bit above horizontal?
Or does it have to come in at same horizontal axis as the toilet drain?
This is the first time I have ever heard of "no vertical offsets on a wet vent", because i used to do it all the time. In fact, the inspectors preferred it that way,
James Henry
Billings, Montana.
So for a wet vent , it looks like you can roll the horizontal wet vent WYE up a bit in the pic below if you wanted to , but no more than 45 degrees, correct?
index.php
Yup. whenever a horizontal drain is tied into another horizontal drain the fitting is rolled up slightly to allow the connecting drain line to start off with the proper grade.
