Toilet & Shower Vent Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Josh Weight, Jan 14, 2020.
  1. Josh Weight
    Josh Weight New Member
    Jan 14, 2020
    Utah
    Hello,
    I am working on a bathroom remodel and have a toilet and shower right next to eachother. I am wondering if my plan shown below will provide adequate venting for both the shower and toilet? Just getting a little confused as to where the vent should be located. Thanks in advance.
  2. Terry
    Aug 17, 2004
    Picking up the shower with a wye and venting the shower does both.
    [​IMG]
    [​IMG]
    Josh Weight likes this.
  4. James Henry
    James Henry In the Trades
    Jul 23, 2019
    Billings, Montana.
    You can do that but the shower drain must be at the same elevation as the toilet drain so the wet vent ties in horizontally. No vertical offsets on a wet vent allowed. " The horizontal pipe acting as the wet vent may not have vertical offsets".
  5. Josh Weight
    Jan 14, 2020
    Utah
    Well dang that's a bummer. Any suggestions on a different configuration? The shower trap comes out at a higher elevation than the closet bend and I don't want to drop the shower trap any more or else it won't be within the floor cavity.
  6. James Henry
    Jul 23, 2019
    Billings, Montana.
    If you can tie a vent straight up off the toilet drain up through the opposite wall, that would do it.
  7. Josh Weight
    Jan 14, 2020
    Utah
    I got it all dry fitted together and I was able to get that shower drain to come in horizontal. Any way you could check out my pictures below and verify that I did it correctly? I greatly appreciate your time and expertise.
    On a side note, I am a structural engineer and if you ever need any engineering help I would love to return the favor :)
  8. Terry
    Aug 17, 2004
    That should work. Here I would need the combo looking up for the vent, but some places are okay with the santee. They used to be okay with that here too when I started off plumbing.
  9. Josh Weight
    Jan 14, 2020
    Utah
    Thanks very much!
  10. Mike Rock
    Mike Rock Member
    Nov 4, 2018
    Long Island, NY
    On a side note, are you allowed to roll the wye up at bit and have the wet vent come in to the toilet drain a bit above horizontal?
    Or does it have to come in at same horizontal axis as the toilet drain?
  11. James Henry
    Jul 23, 2019
    Billings, Montana.
    I'm not an inspector but I would think no more than 22 degrees would be OK.
  12. hj
    This is the first time I have ever heard of "no vertical offsets on a wet vent", because i used to do it all the time. In fact, the inspectors preferred it that way,
  13. James Henry
    Jul 23, 2019
    Billings, Montana.
    Look it up.
  14. James Henry
    Jul 23, 2019
    Billings, Montana.
  15. Mike Rock
    Mike Rock Member
    Nov 4, 2018
    Long Island, NY
  16. James Henry
    Jul 23, 2019
    Billings, Montana.
    Yup. whenever a horizontal drain is tied into another horizontal drain the fitting is rolled up slightly to allow the connecting drain line to start off with the proper grade.
  17. Terry
    Aug 17, 2004
    hj, same here. We do a lot of vertical wet venting in Seattle.
  18. James Henry
    Jul 23, 2019
    Billings, Montana.
    I didn't say no vertical wet vents, I said no vertical OFFSETS on the horizontal wet vent.
Similar Threads: Toilet Shower
Plumbing Forum, Professional & DIY Advice Toilet venting using shower Saturday at 10:48 AM
Plumbing Forum, Professional & DIY Advice Wet Venting shower and toilet only Oct 22, 2019
Plumbing Forum, Professional & DIY Advice Disgusting smell downstairs when showering/ using toilet in upstairs ensuite Oct 7, 2019
Plumbing Forum, Professional & DIY Advice Toilet and Shower drain / vent question (annotated pics attached) Jul 6, 2019
Plumbing Forum, Professional & DIY Advice Toilet gurgling, won't flush with shower running Jul 2, 2019
