Toilet rough-in is 13.5" from finished wall
Joey43
GA
I have access to all the drain components and the 3" basement slab drain. The drain pipe needs to be extended about 1" to better locate the flange. two questions:
How can I extend the horizontal 3" PVC drain pipe approximately 1"?
Is it worth the effort to get the toilet closer than 1.5" to the wall?
John Gayewski
Iowa
No it's not worth the effort. 12" is what we aim for but it's not always perfect. You'll be fine. Happens all the time... not to me though, lol.
Some 14" RI toilets are likely to fit on a 13.5" RI. You need to look at the spec sheets carefully. THen, you can often fudge the position of the toilet on the flange by 1/4-3/8" if needed, so moving the flange, unless you want the toilet to project into the room less, probably isn't worth the effort. Most Toto toilets that use their UniFit adapter have about 3/4" behind them IF the RI is perfect, so one of those, with the 14" UniFit will work. Check the spec sheet however you decide to go.
