Wall hung toilet rough in
whirligiginator
Chicago
Hi,
I am doing the rough in for a client and he is doing all wall hung toilets. Most of my risers are spot on but one of them I was off center by about half an inch. If I push the pipe it will work but I just worry that the pressure will make the plastic drain fitting that comes with the toilet to not be flush with the frame. How much play do you typically have with these toilets in the rough in?
Hi,
Little to none. Best to do a 2x4 carrier with a 2x6 wall.
I agree when I did my own toto wall hung I chose the 2x6 wall and bought the toto carrier. just fix that riser for truoble free install now
Ok I just hate having to put a 3 inch coupling in just to move the riser less than half an inch. I assumed I was going to have to do so though
