Three handle tub valve. Please help
Desa Craig
Seattle
Does anyone know what the bolt below my bathtub knobs are? I'm trying to fix a leaky hot water knob. Thank you
Dj2
California
My guess: to hold the escutcheon (flange).
This faucet trim must be old, I have never seen one like this.
Desa Craig
Seattle
Ok thank you so much! Sorry, can you explain what you mean by 'to hold the escutcheon' ?
Desa Craig
Seattle
So I used the bathtub valve socket to remove this nut, but how do I get this cylinder thing around it off? This part is not unscrewing past a certain point, I don't want to force it.. any ideas?
Dj2
California
Wrap the chrome cylinder with a small cloth and use a channel lock wrench to unscrew it (turn it CCW).
Don't squeeze to hard, you might damage it.
You need to get the stem out, but make sure your water main is off. Take the stem to a plumbing place for a matching replacement.
Desa Craig
Seattle
Three handle valve with integral shutooffs.
You can shut off each side so that you can remove and replace the valve stems without turning off the water to the entire home.
You can also just leave them alone and turn the water off to the home if you want to remove stems.
