Storage Tank_Galvanized Supply
William Rhodes
I have a galvanized supply line showing it's age. I understand it needs to be replaced, but don't have the funds for an immediate fix (runs under retaining wall, under neighbors patio by way of easement over 100yds from my house). I have great pressure, but flow falls off when more than one fixture is being utilized.
Can/Will a storage tank offer a short term solution to my problem? If so, does it require the use of pumps, or can I rely on the city water pressure to fill the tank and provide short term flow in the event of a dishwasher/clothes washer being used while showering?
A well storage tank(s), if large enough, may solve your problem temporarily. The pressure will put water into the tank, and the bladder will keep it up until discharged, but they don't hold all that much water. Depending on the flow you get from your pipe, it may take awhile to recharge. You want enough stored under pressure to meet your needs, so you'd have to estimate that to decide how big of a tank you'd need.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You can fill a storage tank with the city supply and use a booster pump to supply as much pressure as you want to the house.
