Size Of PVC Pipe
winesalot
Chelan, WA
Hi. I need to figure out what size pipe I should us to run water from one end of the building to another.
Here are the details. Service comes in to the building from and underground 2" PVC pipe at 44 psi. (Gravity fed from a cistern) I will run the pipe up to the interior wall to the roofline, then suspend it from the steel purlins and run it 130 feet to a small commercial kitchen and two public bathrooms. I don't mind erring on oversizing it but don't want to be ridiculous about it. My number one concern is I don't want a momentary loss of pressure when some one flushes a toilet or turns on water at a sink.
2" may be overkill on that. Are you using tank toilets or flushometers, because those are sized differently.
This chart is 50 to 80 for PEX
And 40 to 60 for copper sizing
PVC is fine for an underground water service, but not for inside.
winesalot
Chelan, WA
We’ll be using tank toilets.
I’m not sure what that chart is telling me. Can you explain what I am looking at?
