Hello all! I'm stumped, and I'm hoping someone can help. I didn't find an answer using the search function.
I'm installing the following shower controls in a new shower I'm building.
http://www.pricepfister.com/www/ImageAssets/mirror\model\bath\treviso\tre808-5dk\27889-0700.pdf
The shower wall is a standard size (2"x4"). The instructions state that piece "6A" should be flush with the finished wall. It also says on a separate instruction sheet (couldn't find it online) that the finished wall has to be between 2 5/8"- 3 1/2" from the center of the valve body inlets & outlets. I'm using standard 1/2 drywall (Kerdi shower), and my membrane, thinset & tile should be around 1/2" thick. The problem is, this only brings me to about 2 3/8" from the center of the valve to the finished wall.
I had a plumber to the rough-in, and he mounted the valve to a piece of 2"x4" turned sideways and mounted between the studs. I'm sure you know what I mean.
I can't figure out what's going on. The obvious answer is that something thinner should've been used instead of 2x lumber to mount the valve to which would put it farther back into the wall. Everything seems so standard with the construction, yet I'm not falling within the parameters. What gives?
Thanks everyone!
Thanks everyone!
