animalfriend
We need to install a corner shower and found a unit I like (I've only seen a picture so far). I questioned the drain because it looked small and the seller responded and said it's 1.5". We're installing a 2" drain pipe (I believe required by code), but I'm concerned with the 1.5" opening in the base. I understand we could reduce the pipe to accommodate the 1.5" (as if it was a tub). But I'm wondering if the 1.5" drain is allowed in a shower base itself.
It has multiple body-jets, in addition to the showerhead, so it seems there would be even more water than a regular shower, possibly worsening the drain issue.
And finally, it's a 36" corner unit with a curved front and two small doors that meet in the middle of the curve. The jets are directly opposite the door opening and therefore, shoot water directly at the door. I'm concerned it might be inclined to leak. If anyone has any experience with this setup, I'd welcome your input.
Thanks for your time.
