peterng
Good day, bought all I got done tonight was had a beer. That went well.
I don`t know much, but here`s what I can see.
Pump pressure guage reads 40psi. I took the primer cap off, full of water, no pressure. No water coming out of pump and pump not running. Lots of power. I cleaned the contacts. Going down now to see if the tubing to the pressure switch is plugged. Last year I adjusted the pressure switch to shut off around 40psi, though it was set a little higher but can`t remember.
Thing is, there`s no pressure, pressure guages known to go bad are theyÉ
Can I test to see if the impeller is spinning freely without dissasembling the pumpÉ
Diamond 1 1é2hp pump model 313501. It was in the house when we bought it. Age unknown, at least 5 years old.
Thanks,
Pete
Thanks,
Pete
