canadave
I'm considering buying the Santa Rosa toilet, but as I mentioned in an earlier post, distance to wall and height is an issue.
I'm good distance-to-wall-wise up until a height of 27 3/4". At that point, there is a 3/4" protrusion from the wall. So any toilet I install needs to either be lower than 27 3/4", or further than 3/4" from the wall if it's taller than that.
The Santa Rosa spec sheet says it has a distance from wall of only 1/2" and a height of 28 3/16". That height is awfully close to being okay, but of course close isn't quite good enough given the 1/2" clearance required and the 3/4" protrusion from my wall. However, I'm wondering--that 1/2" distance from wall means that's the distance at it's "closest approach". If there's more distance than that from the wall at the very top of the toilet--i.e. the last inch of height--then it might be okay.
Can anyone who has a Santa Rosa confirm whether the inch or two at the top of the toilet is further from the wall than the lower parts? It's hard to tell from photos I've seen online, and the places I've been to look at the toilet all have it up on a display so that I can't see clearly.
