stormlight
Hello, If you drive a Sandpoint down into the ground there is no foot valve. Since you do not have a foot valve is it possible to hook up the sandpoint to an electric pump for irrigation. Or will the pump always loose prime with out a foot valve.
Is the answer to this to put a check valve on the output side of the pump so the suction side of the pump in theory will never looses prime?
If my guess is correct why would one not do this with a standard drilled or augured well and instead us a foot valve. Whats the benefit of using a foot valve in a non sand point well?
thanks
thanks
