rough in photos
demetre
nyc
Few roughing pics from a renovation –
Someone told me the T at the drain for the laundry waste should be a 45 fitting. Is this correct?
Was also told that the roughing from the above floor fixtures in the other pic should not be close elbows but longer sweeps – any input?
Last – there is a pic of a vent at a vanity. A portion of the vent line at the vanity is under 42†height. Is this a problem in terms of how well it will function?
Tom Sawyer
Maine
The tee is fine. What is not fine is the vent. That horizontal bit can't do that until you are 6" above the flood level rim of the fixture.
Nukeman
Nuclear Engineer
VA
Gary: That is all cast iron (not ABS)
OP: The lettering on your pipe is upside-down. Tear it out and replace. :p
Ballvalve
northfork, california
Thats a 20,000$ job you could have done for $3000 in plastic. Best regards to the Mafia!
Tony and his buds just made 2 or 3 grand in union dues. I sure hope thats a hospital and not a house.
Proof positive of why people live in mobile homes or sleep under NYC bridges.
The laundry drain is correct with the santee in that position.
The vent is a little low, but I think you will be fine.
Normally you would have run it over to the side and armed over, allowing the revent to be at the correct height.
Has the job been permitted and inspected? That would enforce the correction of any errors.
Ballvalve, in some buildings we use cast iron. What ever the local code is; we do.
Ballvalve
I hope so, because they would likely charge him to change it. The inspector hits the bars with the guys after work, most likely.
So at least it will be quiet and its keeping a foundry running in the USA.
We don't have friendly inspectors like that here in the Seattle area. If they look at something, and they don't like it, it's up to the plumber to change it to meet the inspection.
If I had done the plumbing, the re-vent would have been at the correct height from the very beginning while the idea was still in my head.
And the bends would have been correct.
It's hard for me to see from the picture exactly what the bends are there, so I would prefer that some on site to see them.
I plumbed this building and parking garage in cast iron pipe; everything inspected and passed off without any changes needed. It was perfect. At least that's what everyone else said about my work.
We had plenty of roof drains and deck drains too. You will notice on the left of the building how it steps to the right was it went up, those are all decks.
Boeing Employee's Credit Union
The parking garage is out of the photo on the right.
Ramon Leigh
Pennsylvania
MC cable normally required if steel studs. I lived in a highrise condo that was in a commercial build zone - steel
studs and MC required thruout. I cannot imagine any residence nowadays using either copper or cast iron.
Tom Sawyer
Maine
We still do a bit of residential in CI for noise reasons.....rich folks usually
