dkate
We installed a Toto Drake on a somewhat uneven porcelain tile floor. There is plumbers putty between the toilet bowl and the floor which is about 3/8" in some areas. The putty has darkened, it attracts dirt, is difficult to clean and appears to be staining the tile (didn't know porcelain could stain). I would like to scrape the putty out to the degree possible and caulk (or silicone) over it. This is primarily a cosmetic issue as the putty looks awful. I realize I'll need to clean the base well to remove the oil from the putty so the caulk can stick. Does this sound like it will work? Any other suggestions? Thanks.
