bhil923
I need to replace my well pump, and wanted to make sure that I am thinking things through correctly. I have gone through websites, forums, and videos to try to make sure that I understood things before bringing up any questions. I bought a 3/1 foreclosure (may change to a 3/2), thus had no info on the well, and it would not pump any water up. After some testing I enlisted some friends to help me pull the pump. The pump is a 4” 8gpm 3/4hp 2-wire 230v Pentair/Myers, and the well is 6” diameter. The pump sits at 237’ with the static water level at 46’ leaving 186’ of water above the pump. The pitless connection piping comes into the basement at about 2ft above the tank bottom.
I want to make sure that I get the best out of replacing the pump, and had a few questions to determine if my thinking is correct and if I am missing anything.
I attempted to calculate the Total Dynamic Head with the assumption that the pump level is at 100ft (I did not have this info), note there is a sediment filter before the pressure tank, but I could not find the friction loss for it. My calculation is: Elevation Head of 100’, Friction Head of 8.8884’ (2x90º elbows and 267’ of 1-1/4” poly), Pressure Head of 138.6 (60PSI) for a Total Dynamic Head of 247.4884. giving this assumption at 8GPM (sticking with what the existing pump was set at) I calculate I need a 3/4hp pump which is what was in there.
I am planning to stick with 230v, the 1-1/4” poly, sediment filter and the single check valve at the pump. I plan to change to a 3-wire with a CSCR control box, and add a CSV before the pressure tank (20gal). I’ll also add a torque arrestor at the pump (none were installed before) and spacers at 10ft intervals.
So my questions are:
Is it safe to assume that the original pump is correct (8GPM 3/4HP)?
Would only having the check valve built into the pump be sufficient?
Are there any calculations that need to change because of the installation of the CSV?
Would changing to a 3-wire and the CSCR help to prolong my installation, as I have read?
Is there anything else you would recommend I do while I have everything removed, or any changes to my ideas?
Thank you very much for your help, I hope this all actually made sense.
-p
-p
