Hey all,
This is what I have:
basement of house-->main shut off (gate valve?)-->water meter-->pressure reducing valve-->second main shut off (gate valve?...identical to first)-->rest of house
Both shut off valves do not close completely, which makes plumbing a real pain. They've probably been there for about 35 years. I am trying to replace the second one (after the water meter) with a 1/4-turn ball valve. What are my options for shutting the water off? Anything I can do with the first gate valve to make it close completely (or at least 99.9%)? Or do I need to shut the water off in the street? I've never had to do that, but I'm assuming that the water company would have to be involved. Or can I sneak out there at night? Haha.
On the first valve, I notice that it allows the lowest water flow before it is completely tightened down. The minimum is just before it bottoms out, but bottoming it out actually increases the flow rate slightly. At this minimum point, I get a flow rate of 1 gallon per half hour (based on watching the water meter).
Prior to me moving into the house 5 years ago, the previous pressure reducing valve was bad and the house pressure was about 150psi. I'm sure that could have worn the valves out faster.
Thanks,
Tyler
First picture shows the water meter, pressure reducing valve, and the shut-off valve that I'm trying to replace. The first shut-off valve, shown in the second picture, is below the water meter.
Thanks,
Tyler
