Replacing a cartridge for an older Moen Monticello faucet
Ray Lopez
New York
I'm replacing the cartridge for an older Moen Monticello faucet because it wouldn't stop running. I removed the old cartridge and replaced with a new cartridge but it still doesn't stop the water flow. Seems like the cartridge doesn't line up properly with the hole in the valve that feeds the spout.
Any advice?
Ray Lopez
New York
Two handle
I think my problem is figuring out how to insert the cartridge correctly so that it lines up with the faucet. There is a tab on the cartridge that should fit in a slot that is about 1.5 inches down into the valve. Whenever I think I have it set right and start to screw in the hold down nut it turns the cartridge out of position.
Any advice on how to insert the cartridge and screw down the plastic nut in the correct position?
When you get it inserted properly insert a Phillips screwdriver through the locknut, and wrench, and press down on the stem to keep it where it belongs.
Ray Lopez
New York
I got the cartridge in place but now the lock nut that came with the stem extensions doesn't screw into place. It just keeps turning without catching. So the cartridge just pops out whenever water is turned on
