I have one of the original San Raphael's (it may have been called a Rialto). It never drained well, and now it does not drain at all. There are no blockages anywhere in the trap or drain. It is very finicky and a pain to work with. Previously, I put in a new flapper/stand pipe assembly. It is also a pain b/c there are three little tabs at the end of three long screws that you use to hold it in place. The problem is that the tabs need something to clamp against and there is very little surface area to do so. In the course of my trying to get it fixed, I have dislodged it and the gasket under the flapper leaks. It looks like I could do a rebuild of most or all of the internals, but I think I will still have the same problem described above. I am feeling ready to replace it. The problem is that the previous owner went with this model b/c they extended the counter with drawers below it to be 5" above to top of the toilet. The point is that I need to find a <21" high toilet or I run the risk of redoing my entire bathroom.
I've looked at the current San Raphaels. They do not get the greatest reviews and they cost at least $750. Can anyone suggest any alternatives for "height challenged toilets"? I do not see much out there.
