Quick vent question (near main stack)
EthylOH
North Andover, Massachusetts
Hi,
I'm adding a new sink right next to my toilet, which is right above the main stack.
Do I need to add a vent for the sink? The waste line will only be 5 feet long from the stack, and about 3 feet vertical (2" drain pipe).
Montreal, Canada
A picture of the ceiling from underneath will be nice.
I wouldn't touch the main stack at all, rubber couplings are not fun to sandwich between verticals.
Cut off whatever is after the toilet, and re-do the toilet as you do the new lav. The new lav is very close to the main stack, it'll get plenty of vent.
I guess this will be an illegal DIY in MA without a permit?
EthylOH
Sorry for the confusion...
I've added some details below:
I'm not cutting into the main stack. I'll be using a rubber donut at the flange to transition from CI to PVC.
If I need to add a vent, it will be up through the wall behind the sink. I'll then tie into the shower and tub aux vent in the attic (it's on the other side of the bathroom).
I was just curious if I needed to vent the sink at all because the drain is so close to the main stack.
The "main stack" is a DRAIN, not a vent, so it CANNOT be used for venting. In addition, the way you have it drawn the sink will have an "S" trap if you do not vent it.
EthylOH
This is what I plan to do. Does it look okay? (I didn't draw in the shower and tub traps etc under the floor)
