I just lost water pressure. Going to pressure tank/switch, I saw my cycle sensor pump monitor blinking rcyc...
I've had that happen once before, about a month ago, and found the air pressure in my tank had bled down to about half of what it should be. I recharged it (it's < 1 year old) and tightened the Schroeder valve.
Today, the pressure in the tank is still 41 PSI. I have the cut-on pressure set to 43. So that appears to be correct.
The rapid cycle timer is set to 30 seconds, and I watched it cycle a few times to make sure the problem didn't immediately repeat - it did not.
So, my question (to @valveman or anyone else) is, what else could cause that rcycl lockout to occur?
I just recently replaced the rusted steel barbed nipple between the pump's check valve and poly tubing, and all appears to be functioning as expected.
