txgoatman
Hi y'all, I need some help deciding on a replacement well pump, and the depth I should set it at.
Here's all the background information available:
I have an existing well (in use) with no records to be found. The driller doesn't have them, the state doesn't have them. I was able to determine that the well is at least 200' (I ran out of string at that point and called it good). The static water level is around 75 ft. Since the wellhead (attached picture) is tied directly to concrete covered steel pipe, I can't pull up the well head with the pump running to test drawdown. The nearest wells for which the state has records have a yield between 5 gpm and 7 gpm, and our house sits between these two, both in elevation and horizontal distance. I am only guessing, but I figure we can count on somewhere above 5 gpm for our well.
The well casing is 6" steel, very old (we have no idea when the well was drilled, but the house was built 1907).
1/2 HP Franklin pump 230v 3wire in the well (no specs other than that which were taken from the control box Model 2801054915)
well x trol tank wx250 (air pre-charge is at 18psi)
pressure switch cut-on pressure is set at 20psi (never builds past that so pump runs all the time).
The drop line appears to be 1" pvc.
The tank is 20' ft from the wellhead, in a shed with a floor about a foot above grade.
I have tested the control box, the tank and the switch; all seem functional. I've opened up everything above ground and don't find any blockage and there are no leaks above ground.
The problem is that the pressure at the tank never builds past 20 psi, and the switch never cuts the pump off.
Water pressure in the house is usable but low some of the time, other times its pitiful. Manually cutting the power to the pump causes the tank to drain and pressure to drop to zero starting immediately, taking about 1 minute to completely empty. There was a checkvalve at the tank, which I have removed in the process of troubleshooting. I think the checkvalve was masking the rapid pressure drop, when I first started looking into the issue.
Now that I've eliminated every potential (that I know of) source of trouble above ground, I believe there is a leak in the drop pipe and water is just emptying back into the well when the pump is off, and that the leak is large enough to keep pressure from building past 20psi when the pump is on.
I'm convinced that I need to pull the well pump and drop pipe, and since it has been at least 20 years since any work has been done on the well, I'm planning to replace both.
(If any of the above doesn't sound right, or indicates a problem I'm not aware of please let me know)
Now, the real question, what size/capacity/brand pump should I replace the old pump with when I pull and replace the drop line? and at what depth should I put the pump?
The house is small, one bathroom (we would like to add another soon), but the well also feeds 8 livestock waterers, and a good size garden. Counting up all the fixtures we are around 12.
I want to replace the pump with something that can accommodate our water usage, without being overkill. I figure on replacing the drop line with 1" or 1 1/4 " poly.
Money is very limited for this project, but we also don't want to put in a junk pump that will just need to be replaced in a couple of years either.
My apologies for the long initial post, but I assume the more info the better.
Any and all advice or comments are welcome. Please help. Thanks!
