got a 10JV1S4-2w230 submersible well pump 175-200ft deep, that started acting up the other day. the water had stopped and gauge was on zero pulled the lever up on pressure switch to restart it and the pump only runs 1-2secs and stops, gauge gets up to around 30psi. the pump dont turn right back on but after about 30secs i can move lever again and it will pump another 1-2 secs.
changed the switch and didnt help, pulled pump the pump looking for a bad wire or something but im getting gettting full volts to the pump and wires looked good.
put pump in trash can of water and hooked a wire up to the pump and it runs good. put a piece of pipe with a gauge on the pump and it builds up to almost 200psi. in the trash can it continues to run as long as i want it to
anyone have any ideas what i should check next?
